Unhook the battery, then turn the ignition to the acc position and wait 5-10 minutes. Then just unscrew the T30 Torx bolts from the rear. It helps if you have the wheel turned for each to bring the bolt to the top so you can get to them easier. Once it is free, pull it out just a bit so you can reach behind it and unplug the connector. It's really simple.
