Hm, i have stock Litronics. They adjust when i start the car. And they are really good.
I had another 986 for cleaning the front radiators. The Litronics in that car were OEM but retrofitted with all sensors. I recognized that the light was by far not as good as in my car. When removing the front bumper and headlamps i recognized that they had used after market connectors for the Litronic mechanism, that could easily fall of the housing. When putting back together everything i fixed that with Gaffa tape, so the plugs can't get off. Now the Litronics adjusted themselves. Low beam and high beam light was much better.
Conclusion: the Litronics are in correct position for driving if they don't adjust themselves. Also you can't adjust manually them from the outside.
Regards, Markus
