Old 12-14-2016, 08:13 AM   #18
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Some clarification:
-Only the cars with factory equipped Lits have self leveling; retrofitting this feature to post delivery Lit installations requires making up the wiring loom, adding the controller, front, and rear sensors, and reprogramming the DME (factory lit cars are actually capable of throwing fault codes for the lights).
-Both factory and post delivery installed Lits are capable of having the Xenon lamp rotate up to fill in the high beams if you have the controller installed and correctly wired into the headlight loom.
Thanks JFP. I personally didn't feel the wiring/controller retrofit was necessary since self level wasn't important to me, as well as the swivel up help from the low beam to high beam, but others I'm sure do. The lights are good, but not great. So be it. I notice that the newer LED headlights on the Acuras are darned bright too, but they seem to glare on oncoming cars.
