Yeah, I have some of those. They are held in by the frame for the adjustment worm gears. Your frame may be broken, causing it to fall out.
I may have a spare frame, too, but replacing it would require disassembly of the headlight. I can send you the parts of you want to try to fix it. Alternatively, you could send me the headlight and I'll fix it for you.
You could just pop a new bevel gear in, but it may fall back out if the frame is broken.
