Old 12-14-2016, 07:46 AM   #2
Smallblock454
Originally Posted by Boxtaboy View Post
They are working correctly. They don't have the feature of self leveling because I chose not to wire in the electronics, but they still are set to whatever beam aim I set it at, and don't move from that height, so it just doesn't dip up when I go downhill or dip down a little when I go uphill, which is the same as what the OEM xenons do in my previous FX35. Self leveling is just an additional nice feature of the OEM lights, but not absolutely necessary and I still can see a long way with the Litronics. They also don't tilt upwards a bit when I turn on the highbeams, but I don't think that is necessary either because the halogen high beams alone are just fine. The only thing is that the newer Xenons today are much brighter and more focused than what I see in the Litronics and in our 05 FX35.
I'm sorry, but you are wrong.
1. they are self leveling - they get the signal from the sensors in the front and rear left. That way they adjust if you have luggage / weight in front and / or back. Nothing to do with up or downhill.
2. the xenon unit doesn't move up and down if you use high beam and don't have the sensors connected.
Regards, Markus
