LOL! That would be an easy fix! Went out this morning after leaving it hooked up to the battery all night. Batt showed 12.9, so no parasitic drain. Would not start. Disconnected and cleaned the quick disconnect and it started, but it would do this before as long as I left the battery disconnected for about ten minutes. Hopefully this will fix the problem. I will keep you guys informed. Thanks again to all!
