Old 12-13-2016, 01:27 AM   #11
geraintthomas
geraintthomas's Avatar
Unfortunately, it's not the simple due to the side lights being positive voltage actuated and the courtesy lights being negative ground actuated. You'd need the diode relay setup that I posted for you.
That's still fairly simple, though. Just use a big a$$ diode to ensure it doesn't break down and cause issues. Forward voltage 20V or more, breakdown (reverse) voltage good and high (30-50V or something).
Watts = volts x amps, so just check the fuse amperage for the circuit you use the diode on and multiply x 15V.
Totally forgot about that relay! That's what I'll have to do
But I'll admit, got quite confused by how you work out the wattage. So, would it be 12v multiply by the amps of the sidelight fuse? :/
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
