Old 12-12-2016, 04:56 PM   #252
PaulE
I removed the transmission, removed the flywheel, I then removed the IMS bearing cover to inspect it and the IMS bearing was in perfect condition, no axial movement. I reinstalled new flywheel bolts and a new clutch kit.
If you went to this much trouble, wouldn't you just replace the IMSB as long as you're already there?
