Old 12-11-2016, 07:18 PM   #11
particlewave
Nice Gelb! Thanks for the links
The Mercedes EGR valve seems to be different
No, it's the same thing.
The SAI changeover valve is simply an on/off vacuum controlled normally closed airflow valve...nothing special about it. The Merc valve does the same thing, has the same size fittings, even the same mold marks. Part #'s are irrelevant. They are the same valve.
Though the specs are identical, I'll go ahead and post up pictures, measurements and results when I replace it.
Thanks Markus!
