Got my tester yesterday and tested the brake fluid in my Boxster. The tester shows a green light which means the tester is ready for a test. A yellow light came on when in the fluid, which indicates less than 1% of moister in the fluid. The tester says 1 to 2% is OK, at 3 % it should be changed. At 4% of water the fluid must be changed urgently! Danger!. LOL! I know many will say regardless change the fluid every two years, and we all know that. It's time for mine to be changed and the fluid is sitting on the bench with my Motive pump. The pumps the ticket!!!! I might add, a reputable Indie in Jax FL uses the same tester when doing PPI's. I plan to test the fluid that I bleed from each caliper.
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
