Raybo, you should use Deoxit on the Imob plugs and any other electroninc items. It;s $$$ but is a very cleaner and corrosion prevention.
The no crank is the symptom of the root cause, if it's the immob, you can make it crank but you will get no spark or fuel injection pulse and it will obviously never start. Yank the immob box from under the seat and take the cover off to inspect for corrosion and bad solder joints. This are getting wet is very very common.
Why was it parked originally?? My guess is the same issue.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
