Old 12-07-2016, 03:36 PM   #7
Coaster
Coaster's Avatar
subscribed...i just installed park distance sensors myself (4 front + 4 back) + 2 blind spot sensors.
up front it is impossible to install an inner mounting system, the bumper is just to close to the cover.
My blind spot sensors have an inner mounting system...and it was not easy to get both of them plain with the surface, depending in the angle and thickness of the cover. sanding inside might help a little.
Which System / kit did you install?
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is online now   Reply With Quote
