Old 12-07-2016, 08:07 AM   #1
JFP in PA
I used anti-seize on the inner part of the wheel carrier that receives the bearing and a little on inside of the wheel bearing before pressing the hub in.
Always an excellent idea; I might add that this is a good application for nickel based anti seize, which has very high temperature (> 2400F) and corrosion (salt, acids, etc.) resistance.
