Originally Posted by bwdz
So I tried using one of those and can't say they seem particularly accurate. Just to test it I poured a little brake fluid in a cup and then started adding water to it, I had to have quite a bit of water mixed in before it read it I think brake fluid is not particularly conductive as water is so it measures resistance and that's how they work
Strange, we tested one against a $145 moisture content tester, using samples from several vehicles, and found the OTC unit to reasonably accurate.
