Originally Posted by particlewave
16" from the floor to the jack points with a 3.7" low profile transmission jack. It came out with plenty of wiggle room. If you took the rear bumper off, you wouldn't even need it that high, but it does help when crawling around under there. After I got the muffler out, I could actually sit under the car cross-legged with my head where the muffler was. With the trans out, I could sit to work on the clutch.
Not nearly as high as I've read others say it needs to be.
Thanks, for the measurement info!
