Thread: Remapping ECU
Old 12-03-2016, 11:49 PM   #24
Steve Tinker
Steve Tinker's Avatar
Yes, Yes & Yes...
Yes you need a different length belt - usually from the underdrive pulley supplier.
Yes a novice can do it if you have a new bolt, Loctite and a good torque wrench.
Yes you can feel the difference but only at low to medium engine speeds. They say about 5 HP max.
Two points of reference: A) don't buy a cheap pulley with large "open" section & thin arms - they break, and B) you lose the engine TDC timing hole drilled in the original solid pulley.
2001 MV Agusta F4.
