Old 12-03-2016, 03:44 PM   #1
Ciao
Ciao's Avatar
Trickle Charger Pops out Of Lighter
I've got the Porche Trickle charger plugged into the Boxster's lighter socket and the unit plugged into the wall (red dot light on). Occasionally, when I notice the red dot light not on on the outlet, I check the socket on the cigarette lighter and it has come loose. Is it supposed to do that or is it loose and I should work on it?
Should the red dot light stay on always?
Thanks,
Rich
5280 Cruising @High Altitude
Seal Gray & K&N Filter
