Thread: Remapping ECU
Old 12-03-2016, 03:00 PM   #19
JFP in PA
Originally Posted by bwdz View Post
Don't buy into that myth, it does not. Read up on it or go the track with your infrared thermometer. It is just for weight reduction because they had to make the rotor larger and thicker.
Both are incorrect; the rotors are cross drilled to allow gases to escape from between the pad and rotors. In dry conditions, the primary gas generation is from the bonding agents that hold the pad together. In the wet, steam is added from the heat. In either case, gas generation between the pad face and the rotor tends to push the pad off the rotor, with a significant loss of breaking effort. Give the gas somewhere to go, and the problem goes away.
