Old 12-03-2016, 05:32 AM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Find a cheap used set of headlights on eBay with good gaskets, swap the good gaskets with yours, then re-sell the headlights. If you do it right, your final cost for good used gaskets will be free-$50.
Yeah, this is a crapshoot though, as you can't really tell from eBay photos if the whole seal is not deteriorating. My seal below in pics...you can't really tell where the seal is mushy cause it's still all intact, for example. Also, most of those headlights are just as old or older than mine, so they're bound to turn to mush too probably. There's got to be a cheaper solution to this problem. I'm thinking even if there was a product like a rubber O-ring (but not formed as an O) would work, as it is rounded and rubber which looks like the factory seal.
