Old 12-01-2016, 08:40 AM   #3
alcubot
Thank you very very much rick!
The first check i'll do, is to see, after remove the plastic cover if the coolant cap looses water with engine in idle.
After that if any loose comes i will open the valve to let any air in the system purge itself.
It's correct?
Thank you in advance!
Antonio
Hi, i'm Antonio from Italy.
Boxter 986 S Year: 1999
alcubot is offline   Reply With Quote
