May be wet a bit still? If you have a vacuum pump or can borrow one, you can place the unit in a thick zip lock bag and pump the air out. This will allow the water to boil off at room temp.
Corrosion is also your enemy. Spray all plugs with Deoxit and stop the corrosion there too.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
