Old 11-30-2016, 04:01 PM   #2
dghii
If all you replace was your battery, you had/have a ground issue. I'd monitor to see if static comes back. Lack of AM is usually caused by a bad ground at the antenna amplifier located in the passenger side A pillar.
Search a bit and you'll see a DYI on getting to the amp and cleaning the connection.
dghii is online now   Reply With Quote
