Old 11-30-2016, 09:31 AM   #1
VII
Another update. I was under the car again double checking that the shift pin bolts were not backed out and in general just poking at things. I took the car for a drive and while it was difficult to shift, there were a couple times I was able to shift from 1st all the way to 5th. Sometimes I would be able to go from 1st to 2nd but then couldn't find 3/4 so I would skip to 5th. I did prove though that I can get the car into every gear.
Right now I can get into 2nd easily and 1st usually. If I can't get into first then shifting into 2nd and then to first usually works well. Going from 2nd to 3rd usually doesn't work but if I skip to 5th I can then shift to 4th and then to 3rd easily. I still have no reverse whatsoever but I can see my reverse light turning on when I'm shifting into 4th and 5th sometimes. I end up grinding a lot of gears while trying to shift too sometimes, mainly into 2nd.
I'm thinking it may actually be a gear alignment or fluid issue. Any other ideas? I'm going to go ahead and just order the shifter alignment tool just to eliminate that entirely.
VII is offline   Reply With Quote
