Old 11-28-2016, 06:09 PM   #14
Ciao
Ciao's Avatar
Originally Posted by Benitom View Post
It takes 1 hour and 45 minutes for the oil to drain
Thanks! It didn't take me so long after all. BTW when checking the oil level (I used 5-40) when I turn off the engine and turn key on to check oil level on the instrument panel the digital display was going up and down for several minutes. After about 15 -30 minutes It finally showed the display on full. I guess it took the oil time to drain into the pan for a valid reading.
5280 Cruising @High Altitude
Seal Gray & K&N Filter
