Old 11-28-2016, 06:18 AM   #15
JFP in PA
Originally Posted by RichRobby View Post
So...... Do vacuum tools help in the draining / flushing of the system in any way or do you still need to go through the routine of removing hoses, tilting the car etc or is there a method of forcing the coolant out through a single drain point on the car?
Seems to me that the draining is the time consuming part.
Sent from my ONE A2003 using Tapatalk
The draining does not change; however, the refill is a 5 min. and you are done proposition with the Uview vacuum system.
