Old 11-27-2016, 05:27 PM   #12
Ciao
Ciao's Avatar
Well if you don't see a pool of oil under the car by late spring then I would think the old ring is ok. I bought 2 LN plugs and a new factory plus 10 rings as JIC stock. Did you get the bit out ok?
No; I haven't attempted it; it is still on the drain plug
5280 Cruising @High Altitude
Seal Gray & K&N Filter
