Old 11-27-2016, 03:36 PM   #7
Ciao
Ciao's Avatar
It's common because the plug is aluminum and the bit is steel, then people use a ratchet to tighten it instead of a torque wrench calibrated to the proper torque.
Avoid it by buying a new drain plug for next time and use a torque wrench (the required torque is very little - 37 ft/lbs for stock plug).
I use a torque wrench religiously, but the bit got stock on the removal. I will need to replace the drain plug but would like to avoid a second or repeated occurrence.
Cheers!
5280 Cruising @High Altitude
Seal Gray & K&N Filter
