Old 11-27-2016, 03:13 PM   #6
particlewave
It's common because the plug is aluminum and the bit is steel, then people use a ratchet to tighten it instead of a torque wrench calibrated to the proper torque.
Avoid it by buying a new drain plug for next time and use a torque wrench (the required torque is very little - 37 ft/lbs for stock plug).
