Old 11-24-2016, 07:41 AM   #11
mikesz
mikesz's Avatar
I have changed coolant when I added the S center radiator to my 99. I also replaced the thermostat, engine mount, and water pump. Didn't find it that difficult. I removed the lower coolant hose that connects to the water pump and drained into a 5 gal storage bin I bought at Walmart then brought the coolant to the recycling station. When I put everything back together I added new fluid and filled as best I could. there is 1 bolt that holds a cover over the oil, coolant in the trunk. remove the bolt and take that cover off. there is a burping valve a little clip on top flip it up start up the car let it run the air will come out and the system has been burped. I had one of those uview devices and sold it. I thought it was a PITA! Review DIY on pelican and pedros board not overly difficult.
99 Porsche Boxster
