Alright, it turns out that the other solution I had been using was also PB blaster. So I re-applied generously, turned up the heat in the garage, and I'll let it sit overnight. However, it has made seemingly zero progress with the hammer method. Would you recommend getting an air hammer and doing it? Or should I just bite the bullet and take it into the local shop
