Old 11-21-2016, 11:37 AM   #10
stelan
stelan's Avatar
Same for me (2000 S with 3.2). Maybe "it" above is referring to the other aftermarket system?
I "think" that up through 2002 our cars use the same AOS (99610702304), then in 2003 the inlet to the block got bigger to let the oil drain faster, so that AOS has a new part number (99610702601) and that maybe some of the hoses are a little different too across the years and sizes.
yes to fit both hoses configuration will be a little different I will include both variations hose sizes, the volume on both OEM AOS does not seem to be that different and easy to compensate with hose lenght so we can use the same vessel that fits well in the engine compartment in the mean time I will test it in my friends 3.2.
this AOS drains into the block via the large block opening so I don't see a problem.
stelan is offline   Reply With Quote
