Old 11-20-2016, 01:30 PM   #350
Ben006
Ben-Auto-Design
Ben006's Avatar
Originally Posted by madmodz View Post
Still can't get my car to drive right. Just got my maf in the mail. I was thinking of going to the stock plenum and tb to see if I can get this car running right. Just put a 2nd new plug in it and switched injector 5 over to injector 6. Still pulling P0306. Hopefully the maf is the issue.
Eddy, did you use the 997 airbox on both runs? That airbox alone should be at least 5-10 hp. Was a fan pointed to your air inlet during dyno.
The MAF would cause all cylinder to go bad.
What have you done so far to correct it?
By the way, I've tried to put the silicon hose like you did Mavis, and it went pretty well, so this is the final solution!
The plenums are officially available!
I realized that mine has been on for around 6000 miles, on trackday and two autocross events already!
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
