Old 11-20-2016, 10:04 AM   #1
50Shadz
Exclamation Cold Start Engine Noise/ Non Magnetic Flakes in Oil filter
Good Morning All,
I am new to this forum and Have a 1998 Porsche Boxster. I have an engine clatter / Rattle in the morning for about 20-30 seconds. Once the oil pressure builds, the noise quiets down to an HLA tick..
Yesterday, I switched oils from Mobil 1 synthetic 10w30 to 5w 40 (Liquimoly). The noise is quieter and for less time when sitting overnight.
I am thinking that the heavier oil is not bleeding down as much as the 10w30 and That
my timing chain tensioners as well as lifters are bleeding down.
I have some questions on this:
Is this non magnetic material due to chain tensioner shoe wear ?
Should The lash adjusters be replaced ?
should the sump plate be removed and checked for debris ?
Has anyone had experience with this ? If so, what repairs did you make ?
Thank
you,
50Shadz
50Shadz is offline   Reply With Quote
