Old 11-18-2016, 04:38 PM   #11
Ben006
Ben-Auto-Design
Ben006's Avatar
Stelan AOS system:
The Stelan AOS system is comprised of the following components:
Separator Can
Manifold
Rubber hoses to replace all accordion plastic hoses
Drivers side engine head fitting to replace plastic fitting
Clamps to replace all plastic pressure clips and o-rings
VW 1.8 Turbo PCV valve to replace OEM integrated PCV
That will prevent a LOT of AOS replacement problems!
What kind of hose did you get for the connection between AOS and plenum? I found most rubber and silicon hose to collapse under vaccum at idle without the proper support :/
Good luck with your idea!
Ben
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
