Thread: Brake Hose ends
Old 11-18-2016, 05:45 AM   #1
Tomkreiner
Troutman hoses are described as steel braided, NOT stainless steel braided, and that's why they need the clear plastic sleeve; to prevent ugly surface rust.
In order to procure the correct hose, however, I need the exact thread description, not just the OD of the hose end. Does anyone know whether the fitting is english or metric? And what the thread might be?
Also, the Earl hoses are available in either 3mm or 4mm ID, which would also need to be known in order to fit the existing hose ends if they must be re-used.
Thanks,
Tom Kreiner
'60 356A coupe
'60 VW 'vert (356 SC engine)
'02 Boxster
Tomkreiner is offline   Reply With Quote
