Old 11-16-2016, 02:49 PM   #274
geraintthomas
geraintthomas's Avatar
To recap, my main beams don't come on when I flash people with the dipped beams off in the day time, as the main beams are linked to the bi-xenon Projectors, so when I pull on the stick to flash people, there's no light to flick up due to the dipped beams being off. So for a work around, I needed a relay to switch circuits when needed.
Created the main beam changeover relay today.
Ready to make it:
Done:
Installed:
Works perfectly! If the xenons aren't on, pulling on the main beam will flash the old separate main beam bulb (perfect for day time flashing). The bulb is now a Cree LED a bulb with a forward facing projector on it, so that it's bright. When the xenons are on though, it'll use the bi-xenon solenoid to flick the projector light upwards and the main beam bulb won't be used.
Perfect.
geraintthomas is offline   Reply With Quote
