Originally Posted by Ben006
You were supposed to cut the accordion hose and reuse the quick disconnect on the AOS, but there is not problem to do like you did
Did it take a lot of effort to get it like that??
Ahh
It took a bit of time but then I put in some very hot water and it went on OK I did it that way because I don't like butchering standard kit in case I have to go back to square one in which case you're kippered unless you have a spare.
