Old 11-15-2016, 01:22 AM   #273
geraintthomas
geraintthomas's Avatar
Depends on how you're going to use them normally. If you just want them to come on with the parking/side lights, then yes.
If you also wanted to tie them in to the courtesy lights, it would be a tiny bit more work.
For example: if you powered them to come on with the parking/side lights, you would feed them a constant 12V+ from the parking light circuit and both the switched ground for the side lights and switched/dimming ground for the courtesy lights. You'd need to add diodes to make sure you don't get wonky behavior. I'll see if I can draw you up a diagram and link some diodes later tonight if you want to do this.
Thank you, I appreciate it
As a totally unrelated question, I'm getting a 996 TT spoiler switch for the dash to re-wire the footwell switch to, which I'm fine in doing. I was just wondering if there was a feed that was live when the spoiler is up, and dead when the spoiler is down, that I could put an LED light onto? The idea is to put a very small LED in the footwell as an indicator to what the spoiler is doing.
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
