Old 11-14-2016, 04:03 PM   #272
particlewave
Depends on how you're going to use them normally. If you just want them to come on with the parking/side lights, then yes.
If you also wanted to tie them in to the courtesy lights, it would be a tiny bit more work.
For example: if you powered them to come on with the parking/side lights, you would feed them a constant 12V+ from the parking light circuit and both the switched ground for the side lights and switched/dimming ground for the courtesy lights. You'd need to add diodes to make sure you don't get wonky behavior. I'll see if I can draw you up a diagram and link some diodes later tonight if you want to do this.
