Old 11-12-2016, 02:50 PM   #264
geraintthomas
geraintthomas's Avatar
Originally Posted by TrumpyAl View Post
The advantages of spending the extra £££ on something like the Morimoto 7.0 are: a proven durable reflector coating, proven reliable solenoid mechanisms, a confirmed very-wide beam pattern and a higher concentration of light at the cut-off (rather than on the ground in front of the car where the glare will contract your pupils and reduce your ability to take see into the distance).
The thing is, it's hard to know what you have so you can't be sure what benefits you would get from upgrading.
Besides...you are soooooo much better with cheap projectors than you are with a halogen setup that it's all a bit of a moot point. Enjoy!!!
Gotcha! It does seem tempting, but like you said Projectors are better than halogens, even cheap ones. I may even upgrade in the future now that the headlight build has gone brilliantly.
I've bought H7 Cree LED bulbs to replace the main beams. ParticleWave has kindly drawn up a wiring diagram that requires a 5-pin relay, but enables the main beams bulbs when the dipped beams aren't on, and switches to the bi-xenon feature when the dipped beams are on. Basically, the mainbeams bulbs will be used just to flash people as I can't flash the HID's, then when the HID's are being used, it'll flick the bi-xenons instead.
Reason for Cree LED's is because I've painted the reflectors black, and a Cree LED bulb has a projector on top of it to project light directly forward, so it'll be brighter to on coming traffic.
The only thing I need to think about are the parking lights. Now that the projectors are in, they're covering the side light bulbs. You can see them in the dark as they illuminate the black surround, but you can't in the day. Wondering what I can do there...
geraintthomas is offline   Reply With Quote
