Old 11-11-2016, 05:16 PM   #385
Ben006
Ben-Auto-Design
Ben006's Avatar
Originally Posted by PaulE View Post
Mine came yesterday. I thought it was going to be made in China but the box said its an Italian company!
It is made in China, they just write BS on the box to look good, but their boxes are correctly sized and quite strong so I reuse them.
That's why I take them apart and control them!
Thanks for sharing your experience with the install!
You shouldn't need to remove the bearing holder, it is tight, but it will go in, even with the bearings on
And thank all of you guys for the support!
If you have any problem with your shifter, you can always post here or ask me via PM or e-mail! I always try to answer as fast as I can.
One last thing, since it works almost completely on metal/metal contacts, vibrations can loosen the bolts (set screws and lever pivot), it doesn't happen often, but it has happened to at least one of you.
Nothing bad, but if you can, check it from time to time
Ben
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
