Old 11-09-2016, 07:37 PM   #17
WRC323
I've purchased an OBC stalk which was previously retrofitted but they had cut off the original connector and installed their own. Not a worry, I can make a harness to suit. But, what are the pinouts for the stalk?
I found the following on Pelican Parts:
Boxster 2001-2004
Connector Pin #2 Gauge Cluster Pin #23 Select Mode Down
Connector Pin #3 Gauge Cluster Pin #22 Speed Alert/Gong
Connector Pin #4 Gauge Cluster Pin #21 Select Mode Forwards
Connector Pin #5 Gauge Cluster Pin #24 Select Mode Backwards
I'm a little confused at "Speed Alert/Gong". The stalk has Select Up and Down, Enter (push?), Escape (pull?)
I've connected a multimeter to the earth and each pin and have found that on mine is:
Red = Down - So Pin #2, connect to #23 on cluster
Yellow = Up - assuming Pin #3 then and connect to #22 on cluster?
Blue = Push - So Pin #4, connect to #21 on cluster
Black = Pull - So Pin #5, connect to #24 on cluster
Can anyone please confirm?
Pic of my stalk:
WRC323 is offline   Reply With Quote
