Old 11-08-2016, 10:15 AM   #7
Coaster
Coaster's Avatar
Originally Posted by lkchris View Post
I replaced my black plastic cowl trim and had no problem removing either wiper arm.
I imagine I opened the hood and maybe even moved it a bit from full open, but didn't disconnect the shocks.
1/4 drive socket equipment is smaller ...
I can get the nut off the stud. I can't get the arm off the stud, it seems it's press fit on. I used a puller to pull the passenger side off and it popped off with some force. I tried to manhandle the drivers side to no avail. Don't want to break the stud or the window.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
