Originally Posted by winter.k
The tire sizes match 996 specs, idk if tires for Boxster 18's are the same, or which offset is for 986. But, if these are from a 911 you will need ~20mm spacers on the rear wheels only. I run the same 996 wheels with 20mm spacers in the summer.
Since these are the reps, I do not believe the spacers are needed. +47 sounds right for a 10" wide Boxster rear wheel. Also those tires sizes are Boxster as well.
TO OP:
Would you consider selling rear set only?
