I think a good PDR should be able to get that.  I would remove the headlight and try to go through there, if they do want to go through the wheel well you may be able to turn the wheel to one side without removing it.  The liner is held on by a few plastic plunger/rivets, and 10mm plastic nuts as Woody mentioned.
