Old 11-01-2016, 02:47 PM   #12
Cbonilla
Got to replacing the non functioning tail light and found out it is still good.
What was happening was the stamped metal power supply lines to the bulb had popped out of the plastic tail light assembly.
Perhaps due to all the years of vibration.
So I just pressed the lines back into plastic assembly and the bulb was tight in its socket and working again.
Had that same problem and it just popped out again and again. A little epoxy and a wrap of electrcal tape to make sure the stamped metal power stayed lines stayed put and the problem was solved. I assume the dealer would have sold me an entire new light assembly
Cbonilla is offline   Reply With Quote
