Old 11-01-2016, 09:27 AM   #11
Muskoka Minute
Muskoka Minute's Avatar
Got to replacing the non functioning tail light and found out it is still good.
What was happening was the stamped metal power supply lines to the bulb had popped out of the plastic tail light assembly.
Perhaps due to all the years of vibration.
So I just pressed the lines back into plastic assembly and the bulb was tight in its socket and working again.
I noticed an extra un-used light bulb socket so I put the new bulb in there. None of the light settings or brakes seem to use this socket when I tested it so I put the new bulb in it so I could find the spare bulb when needed.
Anyone know what the extra bulb socket is for?
On the driver side it is a rear fog light.
If you turn your head light switch to on and then pull it out 2 clicks the rear fog light is activated on mine.
The passenger side is left blank so it won't come on and confuse people.
Hope this helps.
Bart
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
