Old 11-01-2016, 07:54 AM   #10
stelan
stelan's Avatar
Aos being dry does not mean anything, it means that it had time to drain. It ca still be the aos, check for intermix that is the easiest way to see if its a head. Then check compression that is the easiest way to seenif you have a broken or worn ring(s)
Or if you want to believe your mechanic and want to burn money let him do it's thing
stelan is offline   Reply With Quote
