Old 10-30-2016, 11:47 AM   #1
The Radium King
The Radium King's Avatar
i think all good choices. if on a budget, i am running ksport coilovers and they are working good for me (they come with adjustable top mounts too, which let you get more camber without spending more $). also, i have top speed pro rear toe control arms and they are also working fine. depending on how low you set your car (don't set it so low that the lower control arms are past horizontal, otherwise you will lose camber when you load the suspension in turns) you may want to think about bump steer both front and rear - the rear tarett units get a lot more expensive if you want them adjustable for bump steer. for front bump steer, after a bunch or research the cheapest i could find was the stomski units from pelican.
