Old 10-29-2016, 10:55 AM   #1
Pastor T
Top down
Send a message via Skype™ to Pastor T
986 to 987 upgrade, need advice
So I’m thinking of upgrading my 986 to a 987. I’m approaching retirement and want to get something with 60-70k miles around the $15-17,000 range. I’ve seen several good ones but have not begun to do any real research yet. I’m struggling with the idea of having to do the same kind of work on a 987 that I have had to do on my 986. Perhaps I just need to keep my 986. What do you think?
I did a complete financial analysis on my personal history of my car excluding gas, cleaning, and insurance. It is scary to say the least. If I show it to my wife I’m DEAD! Anyway, can anyone give me some feedback on this? Is this normal, above or below what you would expect.
Here is a short history (4 years) of my 986 ownership. It may prove interesting and helpful if you are considering a 986 in your future. I have a MY2000 986 base, Ocean Blue Metallic with grey interior. It had 86000 miles when I purchased it. I have owned it for 4 years and I have put on an additional 47,000. It sits at 133000 right now. It is a mix of around town and highway. Some all out on winding canyon roads. It is my daily driver rain or shine and I usually take it out about 1-2 weekends a month to carve canyons in the mountains near Sacramento where I live. I would consider myself a very spirited driver. That’s why I bought a Boxster. I bought it in 2012 off Craig’s list for 10,500 from the 2nd owner. A fair deal at the time. The records show an engine replacement in 2004 by the original dealer at 46,000 miles with the 1st owner. I figured the IMS blew out, but not certain. I considered the engine replacement a good deal when I purchased it as the IMS issue had probably been dealt with. When I bought it, it seemed like near perfect shape. Very clean, no leaks, and ding free. The driver’s seat was showing wear, but the interior was otherwise near perfect. I flew to Southern California, drove the car, had a PPI done, it checked out and I drove it home. It had slotted and drilled rotors but original brakes. Unbelievably I have not had to change brake pads in 47k miles and they are still good. It needed an alignment and front tires which I replaced immediately. It came with a nice OEM car cover, plastic wind screen, but no headrest windscreens. I received some maintenance documentation but not complete. Since I purchased the car I have completed all regularly scheduled maintenance, including belts and filters. I change the oil (Mobil 1 synthetic 5w40) and filter every 5000 miles. Early on I was very intimidated by working on a Porsche and had to go to the shop. Now I am much more confident and seem to be able to diagnose and fix almost anything. Furthermore, I now have a part time job working at a NAPA parts store so I can get parts very cheap.
So here’s my story:
1st year of ownership; 86000-98000 miles (12K miles)
• I-phone cable; rear speakers, magnetic oil drain plug, front tires, alignment, RF wheel bearing, spark plugs, Battery,
• Total cost Parts; $1335.00; Labor; $673.00
2nd year of ownership; 98000-111000 (11K miles)
• Rear trunk shocks, license plate mounting bracket, rear tires and alignment, water pump, thermostat, serpentine belt, (did the work myself)
• air/oil separator, alternator, complete clutch failure, (replaced clutch, pressure plate, throw out bearing, clutch fork, dual mass flywheel, IMS bearing) Outside shop did all work
• Total cost Parts; $4502.48; Labor; $1473.14
3rd year of ownership; 111000-121000 (10K miles)
• Convertible top replacement; parking brake switch, purge valve, fender liner, several intermittent problems with temp gauge, erratic idle, parking brake switch
• Total cost Parts; $1176.38; Labor; $1430.84
4th year of ownership; 121000-132000 (11K miles)
• O2 sensor, both door latches, front and rear tires and alignment, used seats. Outside shop did the work, I installed the seats.
• Total cost Parts; $3121.83; Labor; $969.35
5th year of ownership; 132000-133000 (1K miles)
• Under body panels replaced, dip stick tube; I did the work.
• Total cost Parts; $596.52; Labor; $00.00
every day is a great day when you are driving a Boxster
Pastor T is offline   Reply With Quote
